#50139 - 06/08/16 11:56 AM GridView RW 9.2B (160505) Paste Extra Row
MarlonMF Offline
Loc: Los Angeles, CA
I have a GridView that shows the discount column from the @O92AHED table. I also have a calculated column which I use to copy and paste the value to the discount column. For some reason, if I have ten rows to copy and paste, everything will paste accordingly except for the last row. What it does is it will insert a blank row before the last (tenth) row.
But if I copy and paste everything except for the last row, it works just fine.
Any thoughts?
Marlon
Edited by MarlonMF (06/08/16 12:02 PM)
#50169 - 06/09/16 03:43 PM Re: GridView RW 9.2B (160505) Paste Extra Row [Re: MarlonMF]
MarlonMF Offline
Has anyone (using GridView RW) replicated the issue?
Any thoughts?
Marlon
#50173 - 06/09/16 05:01 PM Re: GridView RW 9.2B (160505) Paste Extra Row [Re: MarlonMF]
Are copying from Excel? If you are copying from Excel and select the whole column, it copies the heading in the first row and the last row is inserted at the end.
#50175 - 06/09/16 05:41 PM Re: GridView RW 9.2B (160505) Paste Extra Row [Re: Patricia B.]
MarlonMF Offline
No, I'm copying the calculated column (it is on the same view) that is right next to it.
Marlon
#50177 - 06/09/16 08:54 PM Re: GridView RW 9.2B (160505) Paste Extra Row [Re: MarlonMF]
Michael Mulrooney Offline
I duplicated the problem and will have R&D take a look, you will need to continue using the work around you discovered.
2 registered (Tanya_Belanger, Howard S.-MMA), 323 Guests and 5 Spiders online.
14627 Topics
