#4988 - 06/02/05 07:10 PM Inventory 8.0 incompatible?
Nick Sciabica Offline
Loc: Modesto, CA 95350
We have recently upgraded to Adagio Inventory 8.0, however at the time we were still using ACCPAC 6.X. Before the upgrade ACCPAC worked fine, interchangbly with Adagio, now I can not enter ACCPAC Inventory.
Is it the case that we have moved away from the ACCPAC compatible database?
Is it safe to use ACCPAC Order Entry 6.1B?
Is it safe to use ACCPAC Purchase Orders 6.1C?
#4989 - 06/02/05 07:53 PM Re: Inventory 8.0 incompatible?
Hi Nick,
This text is in the 'Important Notes' section of the Readme file for the Adagio Inventory 8.0A upgrade, and the release notes:
quote:
Even though you may have been using Adagio Inventory for some time, if your inventory database was originally created with ACCPAC Plus Inventory Control 6.1B or earlier, it must be converted for compatibility with Adagio Inventory 8.0A. If this is the case, you will receive a warning message when you open your database with Adagio Inventory 8.0A. For details see Considerations for ACCPAC Plus Users.
Here is pertinant text from the 'Considerations for ACCPAC Plus Users section:
quote:
Earlier versions of Adagio Inventory were compatible with ACCPAC Plus Inventory Control 6.1B. Adagio Inventory 8.0A is not compatible with ACCPAC Plus Inventory Control 6.1B. However, Adagio Inventory will convert an ACCPAC Plus Inventory Control 6.1B database to a compatible format. After conversion, you will no longer be able to use ACCPAC Plus Inventory Control 6.1B on the database.
If you have purchases orders created in an ACCPAC Plus IC 6.1B database, you will no longer be able to access them after conversion. Therefore, all purchase orders must be completed and deleted in ACCPAC Plus IC 6.1B, before you convert.
The main issue has to do with the Enter Receipts function, which differs between the 'Plus versions' 6.1B and 6.5A. Using Order Entry or other applications that access Inventory Items is supposed to remain un-affected as the master item database structure is unchanged.
Adagio 8.0A is database compatible with Accpac Plus 6.5A.
#4990 - 06/03/05 01:00 PM Re: Inventory 8.0 incompatible?
In that case you may want to remove 6.1B from the compatibilty list here: http://www.softrak.com/products/reference/comp/comp.pdf
In addition, I am assuming its is ok to use ACCPAC Purchase Orders module?
#4991 - 06/03/05 02:33 PM Re: Inventory 8.0 incompatible?
Hello Nick Sciabica,
Thank you for the note regarding the compatibility chart. The note regarding Accpac IC needs some clarification.
Plus PO 6.1C is not compatible with the Adagio Inventory 8.OA data structure.
#4992 - 06/03/05 09:36 PM Re: Inventory 8.0 incompatible?
Would I be correct in assuming that if I were to upgrade a Plus IC 6.1B user to IC 6.5A, they could then access the Adagio IC 8.0A database from ACCPAC Plus IC?
#4993 - 06/04/05 08:50 AM Re: Inventory 8.0 incompatible?
Hello Steve Schwartz,
Yes.
14630 Topics
