Hello Niko,
This is a Phase 1 error in the IC Item Master file. However, I can not tell you exactly what it is; it may be a problem with the index.
However, once you have made a backup of the dataset, I suggest that you try Rebuild to fix the error. After the Rebuild, Check the integrity of the data again to ensure that there are no other errors.
