Do you mean Fiscal YTD or Calendar YTD?
For Fiscal YTD, this is easy - just print the Trial Balance report from the Reports menu. Or use the Financial Reporter to create and print such a report (either use/modify a sample report or create your own). There are lots of options here.
For calendar YTD, the process is the same if your fiscal year starts on January 1st.
If you want a calendar YTD report and your fiscal year start is not Jan 1, then you cannot use the Trial Balance report to exclude those fiscal periods in the prior calendar year, or include periods at the beginning of the calendar year that are in the prior fiscal year.
However you could create a Financial Report to do this, using formulas to calculate the amounts. Those formulas would need to take the Fiscal YTD and subtract the Net Changes from the prior year. Or add the Net Changes from the prior fiscal year. To be fair, this will involve a little bit of work to get the formulas right, especially for testing when periods are in the correct fiscal/calendar year.
