#4912 - 05/10/05 11:50 AM Custom reporting
With respect to your response below, can the custom report mentioned be incorporated into the existing picking ticket printing, or would it have to be done outside the program? They would need it to function much the same as the existing picking ticket printing if it is outside (i.e. "print picking slips already printed etc..) Can Softrak do this custrom work or is there someone else you could recommend?
Hi pwc,
If your question is to have a detail filter on Print Picking slips to print only items that have a particular location code on the item, then the answer is no. The Location range fields available from Print Picking Slips is based on the value of the location on the Order Header.
You can get this sort of separation of items on an order from a custom report, either from GridView or Crystal Reports for Adagio.
#4913 - 05/12/05 01:21 PM Re: Custom reporting
Another way to relicate the interface is with VBA connected to the Adagio database with OLEDB.
