#48883 - 02/04/16 03:20 PM Order Entry - Current Invoices not purging
A client has OE invoices in their Current list back to 1999. It looks like every invoice for the past 16 years is still in Current.
Their Day End settings are "Purge from current" = 30 and "Purge from History" = 999 days. They run Day End regularly and Orders are properly being purged from Current as part of Day End. Credit Notes have a similar issue though they only date back to 2008.
Data Integrity Check is clear.
What factors does Day End consider when purging Invoices from Current?
OE 9.2. Thank you.
#48884 - 02/04/16 03:39 PM Re: Order Entry - Current Invoices not purging [Re: Bruce Gardner]
Hi Bruce
Look at the print status - they have to be printed to be purged from Current.
Usually that is the culprit.
#48886 - 02/04/16 04:05 PM Re: Order Entry - Current Invoices not purging [Re: Steve Schwartz]
Michael Mulrooney Offline
I suspect that "Order Complete" must also be TRUE.
#48887 - 02/04/16 05:11 PM Re: Order Entry - Current Invoices not purging [Re: Michael Mulrooney]
Bob Wisener Offline
Adagio Conductor
Hi Bruce,
It's checking the following:
Has the invoce been marked as printed?
Is the ship date less than or equal to the invoice date?
Has it already been marked as moved to history?
Is the option in the company profile set to move to history?
Bob Wisener
Dakota Software
#48888 - 02/04/16 05:20 PM Re: Order Entry - Current Invoices not purging [Re: Bob Wisener]
Hi Steve, Michael & Bob:
Thank you for the responses. As predicted by Steve, the invoices are failing the first test "Has the invoice been marked as printed". The invoices for the past 15 years have a Print Status = "Order Confirmation"!
This is a new client to me so I'll call tomorrow and find out why they are processing invoices that way.
#48889 - 02/04/16 05:28 PM Re: Order Entry - Current Invoices not purging [Re: Bruce Gardner]
Hi Bruce,
Thanks for the confirmation. (sorry, I couldn't resist...)
Just so you know, what that means is that an Order Confirmation had been printed for the order, and then after that the order was invoiced. Print statuses carry over from the order to the invoice.
If they email or fax invoices, there are settings in the company profile to 'Mark emailed/faxed/previewed as printed', so they may just not have the profile settings enabled.
#48966 - 02/11/16 12:32 PM Re: Order Entry - Current Invoices not purging [Re: Softrak Support]
Just to wrap up this thread:
The user does indeed use the Order Confirmation button to print "Invoices". They do this before posting the Order into an Invoice. Their rationale is that, in the case of a mistake, they can edit the Order and use the Order Confirmation function to reprint the "Invoice" before posting.
#48970 - 02/11/16 02:10 PM Re: Order Entry - Current Invoices not purging [Re: Bruce Gardner]
I guess nothing they sell is taxable, or do they have quantity shipped on orders enabled?
#48978 - 02/11/16 04:04 PM Re: Order Entry - Current Invoices not purging [Re: Retired_Guy]
Andrew:
They do have "Quantity shipped on orders" enabled. And it's also true that they sell a food product so taxes are generally $0.00 anyway.
#48999 - 02/12/16 04:28 PM Re: Order Entry - Current Invoices not purging [Re: Bruce Gardner]
How were the amounts getting to AR?
#49000 - 02/12/16 04:33 PM Re: Order Entry - Current Invoices not purging [Re: Retired_Guy]
Andrew:
They still do everything normally except that they print the "Invoice" using the Order Confirmation button and only post the Order into an Invoice when everything is correct.
#49001 - 02/12/16 04:54 PM Re: Order Entry - Current Invoices not purging [Re: Bruce Gardner]
Bruce:
Your clients need to bulk print the invoices (after posting to an invoice) from the print invoice function to a PDF file. That will get the flag set correctly and then the invoices will clear to history.
0 registered (), 84 Guests and 2 Spiders online.
