The error message 'The parameter is incorrect' may occur when accessing data stored on a Windows 98 workstation, from a Windows XP workstation on a peer-to-peer connection. This applies to Adagio GridView and the Financial Reporter for Adagio Ledger or Adagio FX, where the application is installed on the Windows XP workstation.
The reason is that the FAT file system is in use on the Win98 station - the problem does not occur if NTFS is used. Also, the error does not occur if the Adagio applications are installed and run from the Win98 workstation.
Resolutions: Either change the file system on the 98 station to NTFS, or install/run Adagio on the 98 station.
