#48338 - 12/22/15 07:24 AM Invoices 9.1A (141016) printing invoices
A client has around 10 Invoices datasets. On 9 of them, when they go to print an invoice, the Invoice spec and Credit note spec fields default to a spec - I believe it defaults to the last one used.
On the 10th one, the Credit note spec field defaults to blank, and they can't print an invoice unless they select a spec from the list (there's only one listed). This is annoying because they aren't even trying to print a credit note.
In all cases, the Specification option is set to "Use selected specification".
This 10th one only has two invoice specs - one invoice and one credit note.
Is there a data file that stores the default spec on this screen? Maybe it has gone bad and needs to be restored or copied from another dataset?
#48343 - 12/22/15 08:08 AM Re: Invoices 9.1A (141016) printing invoices [Re: Steve Schwartz]
Dan_Desautels Offline
Loc: Thunder Bay, ON, Canada
Dan Desautels
DezTek Solutions Inc.
Thunder Bay, ON
#48344 - 12/22/15 08:15 AM Re: Invoices 9.1A (141016) printing invoices [Re: Steve Schwartz]
Do they have "remember report settings" enabled for that user in the 10th data set?
#48354 - 12/23/15 04:14 AM Re: Invoices 9.1A (141016) printing invoices [Re: Retired_Guy]
Andrew - yes, but that setting doesn't apply to printing invoices.
Dan - I'm not sure that thread helped - I changed the name to 8 characters and it didn't stick. Most other spec names in the other datasets are more than 8 characters, so I wasn't optimistic.
I ended up copying a credit note spec over from another dataset, and that did the trick.
0 registered (), 331 Guests and 1 Spider online.
14627 Topics
