#48247 - 12/11/15 09:01 AM OrderEntry 9.2A 150729 Order Action Report
calcompinc Offline
Lady Adagio
Loc: PA
I have a client that is having issues with the Order Action Report alignment. It is related to the length of the item number. Their item numbers are two segments, but the second segment varies in length. Example: SZ-19045 and SZ-19045AC. If the item number is not the last column in the report, everything to the right of the item number is misaligned. From the two items in the example, on the line for the second item, all data to the right of the item number is misaligned by two spaces. After reviewing all of the reports that include item number (in OE, IC, and SA), it was determined that it is just the Order Action Report. The client also posted about this issue (tmolinaro), but this post explains it in greater detail.
Steve Schwartz posted about this issue in August (shown below), but there has been no reply. I spoke with Steve and he is still having issues as well. Is there a resolution to this problem?
Originally Posted By: Steve Schwartz
There is an alignment problem with the Order Action report when the item number is not the last column and there are miscellaneous charges on an order. The miscellaneous charges have fewer digits than a regular item number and all columns to the right are out of alignment as a result.
For now, I am instructing my clients to move the item number to the last field, but this is not always practical, especially if it is a primary sort field.
#48254 - 12/11/15 11:30 AM Re: OrderEntry 9.2A 150729 Order Action Report [Re: calcompinc]
Hi, Carol,
I responded earlier today to another post, perhaps for your client, that I have been able to duplicate this issue with the Order Action report and item numbers using multiple segments. I've reported it to R&D for you.
Thanks for bringing it to our attention again.
#48255 - 12/11/15 12:18 PM Re: OrderEntry 9.2A 150729 Order Action Report [Re: Softrak Support]
calcompinc Offline
Lady Adagio
Loc: PA
Yes, that other post was from the client.
