#47674 - 10/26/15 12:32 AM Upgrade to 9.2a
Relfe Offline
Stranger
Loc: CA
I'm in the process of upgrading our system. We have versions ranging from 8.1 to 9.0d. What is the best way to upgrade our system? Should I start with ODBC, Lanpak, BR and so on or is there a best practice to do perform this?
Our developer also uses ODBC connector to update Adagio database. Any changes to your Database structures that our developer should know?
Thanks!
#47675 - 10/26/15 06:13 AM Re: Upgrade to 9.2a [Re: Relfe]
Hi Relfe
I would start with Lanpak, only because otherwise you will get nag messages reminding you to upgrade it. But the order doesn't really matter.
Payables, Ledger and Receivables had database structure changes moving from 8.1 to 9.x. But my guess is that you are already on 9.x for Ledger and Receivables, since they came out so long ago, so the only module that might be an issue is Payables.
Without knowing exactly your modules and what version they are currently, I cannot give you 100% assurance with regards to your developer. That is the kind of thing your Adagio consultant should be able to tell you.
1 registered (EricHoy), 129 Guests and 0 Spiders online.
14675 Topics
