#47529 - 10/07/15 12:42 PM GL Shutting Down
sunil Offline
Stranger
Loc: new york
I did the upgrade gl9.2A.
I'm having issues with GL on oone workstation
When I start Ledger I get a WARNING. Your Workstation needs to be Updated
once I do the update GL shuts down. I open it up again and the same issue
ap, ar, ic,or, all work fine
#47583 - 10/15/15 12:19 PM Re: GL Shutting Down [Re: sunil]
Hi sunil,
Is this a Windows 8 or 8.1 workstation? We have heard occasional situations of this behaviour, due to a particular Windows Registry setting.
The best known solution is to edit the module.ini file (in your case, \Softrak\Ledger\Ledger.ini), locate the [Master Install Status] section and edit the value ResourceFlags= There should be a P somewhere after the equal sign. Delete the P, then save the file and rerun the program.
If this procedure is more than you feel comfortable attempting, then your Adagio Consultant would be pleased to assist.
As this is a technical support request, rather than a general inquiry, I will move this topic to that forum.
0 registered (), 316 Guests and 0 Spiders online.
14617 Topics
