#47337 - 09/22/15 04:25 PM GL 9.2A Service Pack
ILHS Offline
Casual
Loc: Victoria, BC
I just tried to install the 9.2A service pack and although it appeared to install correctly, it never asked me for a password and when I went into the GL I did not get a warning message or file conversion as described in the upgrade notes.
What have I done wrong?
#47339 - 09/22/15 04:49 PM Re: GL 9.2A Service Pack [Re: ILHS]
Odd that it didn't ask for a password. Service Packs rarely require any kind of database conversion.
Check Help | About to make sure that Ledger is running the release date expected.
Read the release notes for the service pack installed, not the version upgrade (which would require a conversion).
What is the file name that you installed?
Environment including operating systems?
#47340 - 09/22/15 05:12 PM Re: GL 9.2A Service Pack [Re: Douglas Dickie]
ILHS Offline
Casual
Loc: Victoria, BC
Thanks Doug
Ledger Help/About says it's running 9.2A
When I look at the release notes attached to the service pack it appears to be a 9.2A Upgrade. I don't see any notes that specifically refer to a service pack.
The file name installed was ALSPP20150903
I am running Windows 8.1
Carol
#47341 - 09/22/15 06:15 PM Re: GL 9.2A Service Pack [Re: ILHS]
Hi Donna,
Check to make sure that the Help | About version is 9.2A (150903). If it is then the Service Pack installed properly. There is no data conversion with the Service Pack.
You would have been asked for a password to unpack the download, but that would be it. Service packs just fix the current version that is installed, and will not install unless they detect the right version.
#47342 - 09/22/15 06:17 PM Re: GL 9.2A Service Pack [Re: ILHS]
Carol:
When you see the version number in Help | About there is a date code as well. It must match the service pack you installed 20150903, otherwise something is wrong.
If you open Help | Readme | Enhancements & Revisions you will see the release notes by release date. 20150903 doesn't say anything about being an upgrade, instead it just lists the things that have been fixed.
#47354 - 09/23/15 01:08 PM Re: GL 9.2A Service Pack [Re: Douglas Dickie]
ILHS Offline
Casual
Loc: Victoria, BC
It says Adagio Ledger 9.2A (150119)
ADS Version 1.12.61.3245
#47356 - 09/23/15 01:42 PM Re: GL 9.2A Service Pack [Re: ILHS]
OK, then it didn't install correctly.
I'd re-download the Service Pack and repeat the process.
#47376 - 09/25/15 08:52 AM Re: GL 9.2A Service Pack [Re: Retired_Guy]
ILHS Offline
Casual
Loc: Victoria, BC
Thanks Andrew
I watched carefully this time and saw a fleeting alert from Norton; disabled that and it appeared to install properly.
Carol
#47377 - 09/25/15 09:32 AM Re: GL 9.2A Service Pack [Re: ILHS]
Aaaah - those fleeting alerts!
Glad to hear you're up and running.
0 registered (), 161 Guests and 2 Spiders online.
14672 Topics
