#460 - 02/16/00 01:15 PM Re: Quik Reports Ver 6.2B (980817)
Hello, Ziad
There has been an issue discovered regarding printing Compiled reports that have a selection formula that uses Leap Day. QRW gives an error regarding the invalid date if you modify the formula.
If you do not edit the selection formula, the report seems to print fine.
This was discovered using the current release (991217), so upgrading will not solve your problem; try the suggestion above.
BTW, you are not registered for QRWIN. Please fax in your registration form to our Customer Service Department at your earliest convenience.
Thank you.
#462 - 02/21/00 01:40 PM Re: Quik Reports Ver 6.2B (980817)
Hi Ziad,
We found your company's registration in our database. Thank you. We only have you for version 6.2B (971212), but that won't influence this issue.
The above recommendation is to edit the actual report and change the date in the selection formula to Feb 29/2000, save, and recompile the report. Perhaps you can compile to a new file name so that you do not overwrite the current one, and use this temporary executable until it is no longer necessary.
The problem with the leap date occurs only if you have the 'Modify Selection Formula' checkbox marked, bringing up the date information and Feb 29,2000. If you already have Feb 29,2000 in the selection formula, in addition to any other parameters, and run the compiled report without modifying the selection formula, it will print OK without any date errors. I suppose this is a temporary workaround until you no longer require the leap day in the runtime selection.
Alternately, you can run the report from the main program, rather that the compiled report.
