Your Payables check specifcation files will start with 'AP$' and shouldn't 'spontaneously disappear'. Nothing in the application makes any changes to spec files - they are only read when printing checks and at no other time. Edits to a spec can only be done from the designer program.
If you have a data backup, you can restore the particular file(s) you need from there.
