#4505 - 11/24/04 11:59 PM Historical Invoices
Kate Spontak Offline
Loc: New Jersey
In Adagio Invoices, one of my specifications will print an open invoice, but cannot be used to print and invoice from history. It sends out blank sheets of paper as though sending multiple carriage returns. Other specifications print both current and historical invoices.
Has anyone else seen this? Is there some part of the specification that can cause it?
#4506 - 11/25/04 01:38 AM Re: Historical Invoices
Hi Kate Spontak,
Does this happen with any invoice printed from the archive batch? Are there sections defined in the spec for each of the item types on the invoice? Does the spec do the same for the sample data? Does the data pass the integrity check?
Hope you're feeling better!
#4507 - 12/22/04 09:29 PM Re: Historical Invoices
Loc: New Jersey
It does happen with any historical invoice. Sections are defined for item types used. Same result in sample data. Passes DIC.
In preview mode, it shows the hourglass for a few seconds and then exits the program entirely.
#4508 - 12/23/04 07:38 AM Re: Historical Invoices
Hi Kate Spontak,
It sounds like the specification is damaged. One thing to check is the placement of the "End of page" section, and to make sure that there are no fields below the end of the page.
If you want, you can e-mail me the spec and I'll see if we can re-create the problem.
0 registered (), 120 Guests and 6 Spiders online.
14580 Topics
January
