#45015 - 03/19/15 08:01 AM PO filter problem since upgrade
Since we upgraded to PO 9.2A (150217), after each day end we lose all of our filter applied styles. We have to go to Edit/Document Filters and Apply Styles manually on every filter, every morning to get them back.
#45016 - 03/19/15 08:45 AM Re: PO filter problem since upgrade [Re: SusanTennier]
Hi Susan,
The DIC resets all the Filter Styles based on the Filter priority. Check to make sure that the Filters with the styles you want applied have a higher priority (lower number) than other Filter Styles in the list.
In 9.2A you can sort the Filters by Priority sequence which makes this task easier.
#45033 - 03/19/15 04:08 PM Re: PO filter problem since upgrade [Re: Retired_Guy]
Hi Susan,
Do you run DataCare? Another site reported that DataCare is not regenerating the filters and styles, and I have been able to duplicate this problem with PO 9.2A and DC 9.1A.
#45034 - 03/19/15 04:11 PM Re: PO filter problem since upgrade [Re: Softrak Support]
Yes, we run DataCare. Actually it just ran and my PO filters are gone again. They are prioritized as Andrew suggested but that didn't fix it.
#45040 - 03/19/15 05:38 PM Re: PO filter problem since upgrade [Re: SusanTennier]
Bob Wisener Offline
Adagio Conductor
Can you confirm that it's a problem with the rebuilding of PO filters and not a file integrity error and rebuild? The former occurs at the end of the application check.
Bob Wisener
Dakota Software
#45041 - 03/19/15 05:50 PM Re: PO filter problem since upgrade [Re: Bob Wisener]
Hi Bob,
On Monday night I installed:
• Ledger 9.2A Upgrade (150119)
• PO 9.2A Upgrade (150217)
• IC 8.1E Service Pack (150224)
• OE 8.1F Service Pack (150227)
• Sales CQ 8.1C Service Pack (150226)
• Toolkit 9.2A SP2 (150227)
Tuesday/Wednesday/Thursday nights DataCare ran and reported no file or application errors. Everything checked okay.
Adagio PurchaseOrders 9.2A (150217): File Integrity
Filter Matches ... Checked OK
Filter Matches Req ... Checked OK
Filter Master ... Checked OK
Adagio PurchaseOrders 9.2A (150217): File Compaction
Adagio PurchaseOrders 9.2A (150217): Application Integrity
Document Filters ... Checked OK
Requisition Filters ... Checked OK
Yet, each day my PO document filter styles are gone and have to be reapplied.
#45042 - 03/19/15 09:25 PM Re: PO filter problem since upgrade [Re: SusanTennier]
Bob Wisener Offline
Adagio Conductor
As a workaround, if you unselect 'require exclusive access' on the DataCare job, filters will not be rebuilt. I'm assuming it's run during off hours.
Bob Wisener
Dakota Software
#45067 - 03/23/15 03:09 PM Re: PO filter problem since upgrade [Re: SusanTennier]
Hi Susan,
A Hot Fix has been posted to address the DataCare problem.
1 registered (Howard S.-MMA), 180 Guests and 1 Spider online.
14527 Topics
