#4498 - 11/16/04 02:27 PM Unable to write to MENU.INI
Barry French Offline
Adagio Fan
Loc: Kelowna, BC
Adagio GL 8.0B 040518 is running on my computer which acts as a server. We have two additional computers acting as workstations. All 3 computers are using Windows 2000. This setup has been working for many months with no problems. Today, when the workstation attempted to open the GL, the message "Unable to write to K:\SOFTRAK\System\MENU.INI" came up and the GL would not open. This only happens on the one workstation, the other one is fine. Also, A/P and A/R modules run properly from all workstations. I did a reinstall on the workstation and that seemed to work, but only for a couple of hours. Now a reinstall doesn't work at all. I reinstalled Adagio GL on the server but that didn't help. When I go to the MENU.INI file mentioned above, I can't find it. Any suggestions?
#4499 - 11/16/04 05:10 PM Re: Unable to write to MENU.INI
Hi Wilf,
Your problem sounds like a rights issue. Make sure the workstation user has full administrative rights to the softrak directory on the K: drive. I would also refer you to Ralph Allan's posting on setting up a peer to peer network
http://www.softrak.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=1&t=001300
which can help you determine if your installation was performed properly. You can cut and paste the above URL or search our forum for the topic peer to peer installation.
#4500 - 11/16/04 06:16 PM Re: Unable to write to MENU.INI
Adagio Fan
Loc: Kelowna, BC
The gl is working again. The problem in this case appears to have been AVG antivirus software on the computer. When the "heuristic" checker was disabled, the problem went away.
14672 Topics
