#39666 - 12/31/13 10:07 AM Bank Rec - import OFX file too big?
Lisa_Auerbach Offline
Adagio Groupie
Loc: PA
I've been using this module for almost 6 months and have never received this message. The file itself is only 75k. The message states that it cannot exceed 65k. Thoughts?
Thank you.
Lisa Auerbach
#39668 - 12/31/13 04:29 PM Re: Bank Rec - import OFX file too big? [Re: Lisa_Auerbach]
Hi Lisa:
BankRec 8.1E with the November service pack applied will give you that message. You aren't doing anything different or wrong. I encountered this recently myself. The cause is that one of the banks started to supply a non-standard OFX file (it had no end-of-line characters). Without those end-of-line characters, the Bank Reconciliation import process would fail because it found one VERY long line that exceeded 65,000 bytes. Therefore to prevent that problem, BankRec now checks the file-size.
Softrak R&D is looking for a better solution but in the meantime, you should see if your bank can provide a comma-separated file format (CSV). If so, download that file, create an import template that matches and you will be fine. You may need to ask your dealer for help with the import template.
#39681 - 01/02/14 04:07 AM Re: Bank Rec - import OFX file too big? [Re: Bruce Gardner]
Adagio Groupie
Loc: PA
Thank you! I'll try this today.
#39683 - 01/02/14 10:04 AM Re: Bank Rec - import OFX file too big? [Re: Lisa_Auerbach]
Hi Lisa,
Can you email me a copy of the file you cannot import?
Thanks.
#44516 - 02/09/15 09:58 AM Re: Bank Rec - import OFX file too big? [Re: Retired_Guy]
Dan_Desautels Offline
Loc: Thunder Bay, ON, Canada
I just encountered this with my client's OFX file that worked fine in September. Do I have to switch to CSV?
Dan Desautels
DezTek Solutions Inc.
Thunder Bay, ON
#44519 - 02/09/15 11:36 AM Re: Bank Rec - import OFX file too big? [Re: Dan_Desautels]
Hi Dan
From the BankRec 9.2A Release Note
Quote:
  • BankRec 8.1E (2013.11.27) corrected the message BankRec displayed if you attempted to import a bank reconciliation file in OFX format where a block within the file exceeded a size limit. This happened for some banks that removed CR/LFs from their version of the file. However, this caused a problem with size limits of the file that could be imported. The limit has now been removed and most or all large files can now be imported.
#44520 - 02/09/15 12:01 PM Re: Bank Rec - import OFX file too big? [Re: Retired_Guy]
I attempted this import in BankRec 9.2A and it failed. Then attempted the same import in BankRec (2014.01.17) and it was successful. Perhaps 9.2A broke it?
Dan Desautels
Thunder Bay, ON
#44521 - 02/09/15 01:39 PM Re: Bank Rec - import OFX file too big? [Re: Dan_Desautels]
Can you send me the BR files and the one you are trying to import?
Thanks.
#44529 - 02/10/15 08:34 AM Re: Bank Rec - import OFX file too big? [Re: Dan_Desautels]
Yes, indeed. This is broken in BankRec 9.2A.
We'll address this sooner, rather than later, and I apologize for the inconvenience.
#44593 - 02/15/15 07:35 AM Re: Bank Rec - import OFX file too big? [Re: Dan_Desautels]
A Hot Fix has been released to fix this issue in 9.2A.
I'm sorry for the inconvenience.
1 registered (Tanya_Belanger), 198 Guests and 6 Spiders online.
14576 Topics
