#4375 - 10/04/04 03:25 PM Re: Invoice module error: "Internal error (2708) file handle invalid"
Hello JPBoudreau,
When do you receive the error? What are you trying to do when it appears?
I have seen the error in the past, when the attributes for an Adagio program file were flagged as Read-only.
#4377 - 10/04/04 06:15 PM Re: Invoice module error: "Internal error (2708) file handle invalid"
Hi JPBoudreau,
If the files were copied from a CD, then they will be marked as read-only. Make sure that all the files are marked read-write.
#4379 - 10/04/04 07:38 PM Re: Invoice module error: "Internal error (2708) file handle invalid"
Even the Administrator with full access to everything cannot write to a file flagged as read only.
Go to a DOS prompt.
Change to the root of the drive you have Softrak and the data installed on.
Type the following;
c:\windows\command\attrib -r *.* /s
#4380 - 10/05/04 10:11 AM Re: Invoice module error: "Internal error (2708) file handle invalid"
Hello JP,
As a Windows application, Adagio does not require a setting for file handles. Only DOS needs this.
0 registered (), 174 Guests and 0 Spiders online.
