#42035 - 06/24/14 07:42 AM changing format of cheques
IreneHelie Offline
Loc: Vernon, BC, Canada
I am changing the format of our cheques and I cannot get the maintain specificiations
to work.
HELP
Daffy Duck
#42036 - 06/24/14 07:46 AM Re: changing format of cheques [Re: IreneHelie]
"Cannot get it to work" is a bit vague.
Does it launch? Will it open your specification? Can you make and save a change to your specification (Just a simple one like adding some text).
#42037 - 06/24/14 07:53 AM Re: changing format of cheques [Re: Retired_Guy]
IreneHelie Offline
iT DOES NOT LAUNCH, I tried to open an advice, advice, cheque format. We downloaded
payables on a new computer and somehow I cannot get the cheque format to come up
in the printer file. So i went in and redesigned a cheque format but it will does not work
either.
really at a standstill
thank you
Daffy Duck
#42038 - 06/24/14 08:17 AM Re: changing format of cheques [Re: IreneHelie]
Normally, your Adagio Consultant would help install Adagio on a new computer to help avoid things like this.
Did you re-install Payables on the new computer or just copy files over from the old computer? What happens when you choose "Maintain Specifications" from the Adagio Payables menu? Do you get an error message of any description? If the Designer opens, but then you cannot open any specification, then that's a different problem.
The specifications are stored with your Adagio Payables data. If Adagio Payables is running there normally would be any further need for adjustment.
#42039 - 06/24/14 08:29 AM Re: changing format of cheques [Re: Retired_Guy]
IreneHelie Offline
I reinstalled from the softrak website the whole program. I did not copy from another computer.
I can open specifications and get one file name but when i go to print and pull in the file name
i cannot access that file with the format i want.
I want an advice,advance cheque format and i save that on a file but when i pull up that file
in the print cheques it is blank so i have not saved it but i did not create it. so i am going in
circles.
thanks
Daffy Duck
#42040 - 06/24/14 08:34 AM Re: changing format of cheques [Re: IreneHelie]
Irene:
This is not an issue easily solvable over the forum, I'll have someone form our office give you a call and investigate the problem.
#42042 - 06/24/14 08:51 AM Re: changing format of cheques [Re: IreneHelie]
If you don't change the name of the specification under File | Options then it is likely that you are selecting the original specification when you test.
#42044 - 06/24/14 09:33 AM Re: changing format of cheques [Re: Retired_Guy]
Andrew:
To change the cheque specification one is using you must Edit | Bank.
#42048 - 06/24/14 10:09 AM Re: changing format of cheques [Re: Douglas Dickie]
IreneHelie Offline
what configuration ini file do i adjust to adjust the font size in the cheque design of adagio payables
line to adjust for the font name.. if the name is not there then you need the exact line name.. do you have an example?
Daffy Duck
#42051 - 06/24/14 11:04 AM Re: changing format of cheques [Re: IreneHelie]
There is a recorded webinar on how the Check Specification Designer works available for viewing on our web site.
0 registered (), 382 Guests and 2 Spiders online.
14627 Topics
