#42022 - 06/23/14 08:53 AM Upgrade issues
FSR Offline
Stranger
Loc: Regina, Sask, Canada
We recently upgraded our Adagio software to Adagio FX 9.0B (2011.11.24).
Now have problems with Statement of Earnings report.
All budget columns are double the amount they should be.
And all Revenue budget columns are indicated as negative amounts.
How do I fix this?
#42023 - 06/23/14 09:24 AM Re: Upgrade issues [Re: FSR]
From the Release Note:
Quote:
• Compatible with Simply Accounting 2012. Note: Budgets are retrieved as they were entered in Simply - the sign is flipped on Revenue accounts.
We would recommend using the tools to export / import and edit budgets in FX to get the numbers the way you wish and then disabling the retrieve of the budget figures on the retrieve dialog.
#42024 - 06/23/14 10:14 AM Re: Upgrade issues [Re: Retired_Guy]
FSR Offline
Stranger
Have exported budget from Sage 50 and saved as ascii csv file. Tried to import into Adagio and got stuck at
question record as net changes. Have tried that but still no luck. Further advice?
#42025 - 06/23/14 10:20 AM Re: Upgrade issues [Re: FSR]
You want to import the Budget numbers, not the net changes. These are two separate imports
#42026 - 06/23/14 10:23 AM Re: Upgrade issues [Re: Retired_Guy]
FSR Offline
Stranger
Budget numbers does not come up as an option
#42027 - 06/23/14 10:25 AM Re: Upgrade issues [Re: Retired_Guy]
And if you mean the screen that says 'Import figures as net changes' after choosing to import the Budget file, then you can simply click the Import button to continue.
An ancient implementation of importing within the program allowed a second option to add the imported values to the existing values, but that option is no longer supported. The only remaining option here is 'Net changes'.
#42028 - 06/23/14 10:34 AM Re: Upgrade issues [Re: Softrak Support]
FSR Offline
Stranger
Yes, that is the screen I meant, I have clicked the import button to continue and get the following error message
Invalid date '21001/1' for field call 'Acct/Dept" of record 1
How do I fix that?
#42049 - 06/24/14 10:44 AM Re: Upgrade issues [Re: FSR]
The Account and Department were in the same column. They need to be 2 separate columns to match the Import template.
0 registered (), 72 Guests and 3 Spiders online.
14527 Topics
