Does anyone know why when I auto generate a purchase order with the following settings, the computer does not calculate the quantity correctly for non stock items (no min/max/reorder)
quantity on SO is 24 quantity on Hand is 0 quantity on PO is 0
auto generating for Inventory with following selections: Primary vendors Below minimum Up to maximum Calculated quantity
We use the term non stock to refer to Items we do not stock on our shelves but will order in if a customer requests it. We treat them the same as a stock item but keep zero on hand. We still use Purchase Orders 8.1B because it orders the correct amount.
Thank you for looking in to this. Unfortunately if I order to above maximum I will have to reduce the maximum on over 1200 items or we will over order for every item in our warehouse and then have to increase them again when problem is fixed.
Softrak Support
I also had success with setting a maximum of 1 on the non stock Item. With this setting and your generate options, I get 24 when I choose Purchase qty Up to maximum and 25 if it is Above maximum.
Regards, Softrak Tech Support
