#4192 - 07/21/04 03:11 AM Adagio from single user to LAN
Ralph Allan Offline
I am going to be converting a user's system from a single user/PC installation to a peer-to-peer LAN.
Can I do this:
- Create a shared folder
- Net use it as, say, drive F (Windows XP Pro)
- Move the Softrak folder and all sufolders to F:
- Run the workstation install to update the registry entries
- Map the shared folder on the other PCs and run workstation install as usual,
or must I reinstall the applications and service packs?
#4193 - 07/21/04 03:43 AM Re: Adagio from single user to LAN
Hi Ralph,
Assuming that the original installation of Adagio went to the C: drive, there will be some system file paths that have C: hardcoded (ie the choice for the report tables drive). Simply copying program directories will not update these files, thus when you attempt to run workstation setup, it will give you warnings or errors regarding unexpected paths such as above.
When the system is changing so that users recognize the Adagio program drive as a different letter, you really should reinstall software just to be safe that everything updates OK.
If this were a brand new peer-peer install, then the setup you described is fine (of course substituting 'move the Softrak folder' with 'install Adagio'.
0 registered (), 60 Guests and 0 Spiders online.
