Previous Thread
Next Thread
Print Thread
#41893 06/09/14 06:45 PM
B
Adagio Prodigy
Adagio Prodigy
B Offline
We are using AR 9.0C.
We must export notes (which are quite voluminous) and found that if we export from AR directly, the notes stop exporting after a customer in the "B" section of the alphabet. Not sure why the stoppage, but it is the same for each export we try. If we then try the export again, starting with the next customer AFTER that one, it will only export notes one customer at a time. I've not run into anything like this before.
We also tried using GridView to export this large list of notes, but GridView only gives approx 20 characters for each column, and then stops. It seems to be more complete than an export from AR directly in that it exports all customers and all notes, is there any way to make the length of the column longer in the GridView export?
Some notes can be quite detailed, it would be nice to have them complete, rather than simply the first 20 characters. Possible?
Barb
Barb:
The only time I've experienced this problem is with a client who copied notes from Outlook. The formatting codes (which you can't see) were causing issues with exporting notes.
In GridView, make sure you are using the Note Details rather than Note Headers.
What format are you exporting to?
Moderated by  Softrak Support
Link Copied to Clipboard
Who's Online Now
0 members (), 136 guests, and 3 robots.
Forum Statistics
Forums5
Topics14,679
Posts71,625
Members1,874
Most Online1,408
Dec 9th, 2025
S M T W T F S
1 2 3 4 5 6 7
29 30
