#41770 - 06/02/14 08:37 AM ODBC Connection
GMacF Offline
Hi I am a development partner and I am trying to get a query to work against the sample data.
I want to query 3 tables.
G/L Account Master
G/L Account Net Changes
G/L Posted Transactions
I believe G/L Posted Transactions is GLPST. I was able to setup an ODBC connection that pointed to the SAMDATA but when I do a select * from GLPST I get....
[Softrak Systems][Adagio](18) The file set 'GLPST' does not exist.
Any help would be much appreciated...
Dynac.
Gary Macfarlane
http://www.Dynac.ca
Imagine: Excelling without traditional Spreadsheets!
#41780 - 06/02/14 10:11 AM Re: ODBC Connection [Re: GMacF]
Michael Mulrooney Offline
You need to use the DataDictExporter that is in the ..\Softrak\System folder pointed at the sample data and export the "table and field names" to Excel
...\Softrak\system\DataDictionaryExporter.exe /ODBC /A /H
The ADS Alias tag is what ODBC uses to access the data not the Windows "File Name". For the General Ledger all Alias's begin with AL90D.
Select * from AL90DPST_PST should work for your query, the extra _PST is required because the same table definition is used for multiple files.
You should also edit the DSN Table Selection to choose
AL90DMST |AL90DBUK | AL90DPST | AP90DGLO
you will be shown only the tables of interest
I always suggest using Excel or MSQuery to make some initial probes into the data
Edited by Michael Mulrooney (06/02/14 10:12 AM)
#41786 - 06/03/14 07:07 AM Re: ODBC Connection [Re: Michael Mulrooney]
GMacF Offline
Thanks Michael,
I have exported the Data Dictionary table but I am still a little confused on how to setup the DSN or how to query the G/L Account Master (@L90DMST = ADS Alias). I am using the latest Adagio.
The steps I took are:
Only option specified was the DataSource. There are no options behind the test successful popup.
Was successful in connecting to the data source but failed to query a table.
Gary Macfarlane
http://www.Dynac.ca
0 registered (), 459 Guests and 5 Spiders online.
14627 Topics
