#40944 - 04/02/14 12:33 PM Current Versions
I’m a little confused why I’m getting this when I run chksys.exe:
The following Adagio programs are not Current:
Adagio Inventory; Version: 8.1D (120126) [must be version: 8.1E (140330)]
Adagio OrderEntry; Version: 8.1F (130918) HF [must be version: 8.1F (131106) HF]
I confirmed I am running these:
IC 8.1D (120126)
OE 8.1F (130918)
However I do not know where to find these more current versions?
The Softrak website under full releases shows these versions:
IC Latest Full Release 8.1D 2012-01-26
OE Latest Full Release 8.1F 2013-07-08
I assume that IC is coming soon, but where is OE 8.1F (131106)??
#40945 - 04/02/14 12:43 PM Re: Current Versions [Re: SusanTennier]
Hi Susan,
You are correct that a release for Adagio Inventory is imminent.
The release for OrderEntry 8.1F dated Nov 6, 2013 is also a hot fix, rather than an upgrade or service pack, as indicated in the version check message. This is why that release date doesn't appear on the 'latest full release' list - the last release not a hot fix was July 8, 2013. All Hot Fixes are obtained through your Adagio Consultant, who should know whether or not you require the Hot Fix.
If you are concerned that the Nov 6 Hot Fix has something you require, here is a list of the changes:
After installing the 8.1F (2013.09.18) Hot Fix, Adagio ePrint users received the error "Attempting to perform operation on unopened OE Order Header file." when accessing documents when filters were applied.
In the column editor for the Edit Items function the Qty on SO and Qty on PO fields were reversed.
The Fax Queue Listing report could not be printed in OrderEntry 8.1F.
Invoices and credit notes containing a dash in the manually assigned document number were not visible in OrderEntry or from Edit/View Customer and could not be attached to statements in Receivables by Adagio ePrint users because the dash was stripped from the PDF file name.
The splash screen for the specification designer indicated OE 8.1F was not registered and licensed when in fact it was.
