#40717 - 03/19/14 11:27 AM PO amounts in Ledger
Is there a way to have PO send the ADJ # to Ledger instead of the PO or RC?
#40719 - 03/19/14 01:34 PM Re: PO amounts in Ledger [Re: SusanTennier]
Hi Susan,
In addition to the standard selections for the Send to GL Reference/Description choices, here are the available codes for defining User-specified information to send from PO documents to Adagio Ledger batch descriptions:
%ono - for Original Document code
%des - for Document description
%dno - for Document code
%ref - for Reference
%rno - for Receipt code
%ven - for Vendor code
%vnm - for Vendor name
%vdn - for Vendor Document code
%job - for Job
I suspect that you are looking for the actual document number, rather than the vendor document number, nor the original document number (ie the PO# for a receipt, or the receipt# for a cost adjustment or invoice). Thus the User-specified code of %dno will output ADJ-100001 or whatever the adjustment number is. Of course, this will affect all transactions that generate GL activity and not just for invoice/adjustments, so you need to determine if this is what you require.
#40721 - 03/19/14 01:52 PM Re: PO amounts in Ledger [Re: Softrak Support]
In PO's Company Profile, Ledger Interface Tab we have these options:
Send to G/L as transaction comment: Purchase Order description
Send to G/L reference field: Original document number
Send to G/L description field 1: Vendor Name
Send to G/L description field 2: Receipt number
When I look at an account in G/L (i.e. 2015 A/P Clearing), I see in the grid, the Reference showing the PO# and the Description showing the Vendor Name. So, it's the Reference field that I would like to change to the ADJ#.
In PO's Company Profile on the Ledger Interface tab, the option "Send to G/L reference field" does not offer "Document code" as an option. How do I set it to %dno?
#40722 - 03/19/14 01:55 PM Re: PO amounts in Ledger [Re: SusanTennier]
Sorry, but the G/L Reference field does not support the user-specified codes. Only the 2 G/L description codes.
We'd have to add Document code as a new Send to G/L Reference choice.
#40723 - 03/19/14 02:03 PM Re: PO amounts in Ledger [Re: Softrak Support]
The interesting thing is that on the Integration tab of PO's Company Profile, we have:
Send to AP reference field: Original doc number
Send to AP description field: Receipt number
Actually what it sends to AP is the RC (Receipt number) to the Reference field and the ADJ (Invoice) to the description field. Document Code it's not even an option that's available but we're getting the ADJ# in AP. If this is a glitch, it is a great one!
Hope you can add the ability to send ADJ#'s to Ledger.
#40742 - 03/20/14 12:00 PM Re: PO amounts in Ledger [Re: SusanTennier]
Hi, Susan,
You are also able to send more than one user defined code to GL within the Description fields. For example, you might send:
%dno %vnm As space is limited, you would want to use the smaller code first as it's possible that the information for the second code would be truncated, or not, depending on how many characters the information uses.
1 registered (Tanya_Belanger), 52 Guests and 3 Spiders online.
14663 Topics
