#40584 - 03/11/14 12:15 PM order entry/orders/picking slips
Debbie Offline
How do you change the form here for picking slips?
#40585 - 03/11/14 01:27 PM Re: order entry/orders/picking slips [Re: Debbie]
Donna:
Do you mean "I currently have form A as the default and I would like to change to form B?"
This is controlled separately for each user. In Adagio Order Entry access File | Workstation options. On the specification tab you can change the default form.
If this isn't what you are looking for please explain the problem in more detail including which version of Order Entry you are using.
#40592 - 03/12/14 10:14 AM Re: order entry/orders/picking slips [Re: Douglas Dickie]
Debbie Offline
We are using oe 8.1F
actually I would like to eprint page 2 only of a picking slip right now eprint only prints page one
#40594 - 03/12/14 10:26 AM Re: order entry/orders/picking slips [Re: Debbie]
Hi Donna,
Why not make "Page 2" of your spec a "Page 1" of a different specification?
#40596 - 03/12/14 11:10 AM Re: order entry/orders/picking slips [Re: Retired_Guy]
Debbie Offline
I dont know how to delete a page in order designer
#40597 - 03/12/14 11:13 AM Re: order entry/orders/picking slips [Re: Debbie]
Debbie Offline
Also just wonderig how to change my name as Donna passed away in 2012 I have changed by profile but still comes up Donna?
#40598 - 03/12/14 11:32 AM Re: order entry/orders/picking slips [Re: Debbie]
Debbie Offline
OK managed to get just page one (spec option 1 page) changing page 1 to page 2 but what if I want to delete page 3 of 4 page document.
#40600 - 03/12/14 11:47 AM Re: order entry/orders/picking slips [Re: Debbie]
Hi Donna,
For your question about changing the name of the Forum name, I suspect that you will need to re-register for the forum under a new desired name. I looked at what is editable from the My Stuff / Edit Profile screen, and the user name was not editable.
For your question about pages when printing specs, you can define a number of copies on the specification template, by using Maintenance / Maintain Specifications and defining the number of copies from File / Specification Options. It sounds like you already found this from one of your posts earlier in this thread. And when emailing, faxing or ePrinting a form, copy 1 is always the only copy sent to the customer. Additional copies are only for internal use only.
If you happen to be printing a form for a large order that requires more than one page to fit all the details, there is no way to indicate that you want to print particular pages of that form and not others. All pages will always print.
If you could indicate how many copies that your specification is set to print, and how many pages each copy of the picking slip is, and what you mean by 'deleting page 3 of 4', we might be able to answer the question better. Depending on your requirements, the answer might require the use of an add-on product such as PrintBoss, or other changes to your specifications.
0 registered (), 191 Guests and 1 Spider online.
1865 Members
14498 Topics
29 30
