#4015 - 05/04/04 12:20 PM Re: AP Year End
Hi Clark,
Which procedures did the Year End Processing screen indicate were not yet completed? Are there posting journals that need to be cleared, or the GL batch needs to be retrieved, or something else? Knowing which steps are listed as incomplete will help.
One step that we have run into a few times is that a particular posting journal was printed and cleared, but for some reason the file size of the posting journal file was not set to zero. Thus Year End still thinks that step is necessary. The solution is to manually remove the file; all posting journal files in Payables start with the letters "APPOST". If you have printed and cleared all of the journals (including the register and check reconciliation) then you can remove all files that start with APPOST. They will be recreated automatically the next time you post.
If you want to be safe, make sure you have a data backup before doing all this, though since it's year end I'm sure you already have one.
#4017 - 05/05/04 03:23 AM Re: AP Year End
Hi Clark,
Month end processing will always be allowed to proceed if there are some procedures listed, as at period end these are 'recommended' but not 'required'. For Year end processing, all these same steps are 'required'. Until all steps are complete, the Proceed button will remain inactive.
So when you first access Year End in Adagio Payables, there is no list of procedures (such as open batches to post, posting journals to clear, or other steps)? What version of Adagio Payables is in use? Depending on the version, you will either see a drop-down field or a list of procedures, with either 'OK' or 'must complete'. What does the Year End window look like for you?
In addition to clearing each of the 5 different posting journals, you must not have any open batches (invoices, manual checks, or adjustments) and the sub-ledger batch must be retrieved into Ledger. Check these out in case one of these is the hold-up.
