#401 - 01/07/00 10:13 PM Quick Reports 6.5 and IC 6.1B to 6.5 conversion
I am having a problem getting Quick Reports 6.5 to convert a report that was set-up for Inventory Control 6.1B to IC6.5. I have all current PTF's for WSM 7.0 and IC 6.5. Does anyone know why the procedure as outlined in Quick Reports might not work? I open and save the report files with IC6.1B installed to convert them to the new Quick Reports, then I install data to IC6.5 and try to reopen the report files with conversion turned on. It starts it's cross table check then stops with a warning message "Required Table IC6.1B not found.Use install data" ...Of course it's not found! Please help!
#402 - 01/10/00 12:22 PM Re: Quick Reports 6.5 and IC 6.1B to 6.5 conversion
Hello Steve,
I emailed you a PTF for converting IC 61B reports to 65A on Friday.
With the 11/16/99 QR PTF installed, follow the steps in Chapter 11 of the manual.
Open and save the report with the IC 61B table selected in Options/Install Data.
Turn on Conversion and then open and save the report with the IC 65A tables selected in Options/Install Data.
0 registered (), 235 Guests and 2 Spiders online.
14666 Topics
