#39886 - 01/16/14 06:39 AM Gridview Columns
MarieEve Offline
Stranger
Loc: Ottawa, Ontario, Canada
I run a lot of Gridview reports. Is there a way to change the order in which the columns are displayed? (the column that appears a the far right should actually be the first column on the left... others are in the wrong order as well)
#39887 - 01/16/14 06:51 AM Re: Gridview Columns [Re: MarieEve]
Lauren Stief Offline
Adagio Padawan
Loc: Waterloo, ON
Hi MarieEve,
You definitely can! Make sure that your view is expanded and then hold you mouse over the title of the column (ie. Customer Number). Click the left mouse down and drag the column to the spot you would like it to appear on the grid. The mouse cursor should be a white arrow for you to be able to move the columns around. You will see a red line when you are moving them, wherever the red line appears is where you will be moving the column too.
Cheers,
Lauren
Edited by Lauren Stief (01/16/14 06:55 AM)
Lauren Stief
Adagio Solutions and Support
1-800-540-3164
#39888 - 01/16/14 07:01 AM Re: Gridview Columns [Re: Lauren Stief]
MarieEve Offline
Stranger
I tried that and they won't move. frown
When I hover over the column titles, the arrow becomes a black arrow, pointing down.
#39889 - 01/16/14 07:05 AM Re: Gridview Columns [Re: MarieEve]
Make sure the View isn't summarized (the summary button should be off). Click the column you want to move once so that it is selected. Then click and drag the column to the new position.
#39890 - 01/16/14 07:06 AM Re: Gridview Columns [Re: Retired_Guy]
MarieEve Offline
Stranger
Ahhhh... The "click on it once to select it" is what I wasn't doing. Thank you so much!!!
1 registered (Softrak Support), 257 Guests and 2 Spiders online.
14617 Topics
