Hello JPBoudreau,
Well - we managed to download the driver you pointed to an get it loaded on a Windows 98 mahcine... Unfortunately, here's the report on the results:
We was unable to get the PCL6 driver for the HP2300 to work at all from AP. It hangs AP. It won?t print a test page properly. When printing from Word 97, I get a ?PCL XL error?. We gave up on that driver.
With PCL5e driver:
- Won?t print a test page properly on the 8000 or other 2 HP machines on our network. Prints black bars for text.
- Prints a totally black page when print a check from AP.
- Prints a test doc from Word okay (but we're not sure what that proves)
- Previews a check (with MICR) to screen without an error
- Prints a check to file (via the driver) without an error
So, we can?t get the 2300 driver to work properly on any printer we have here. But, printing to a file should have caused any error that would have happened if printing to the printer. The PCL5 driver for Softrak's HP 8000 does work okay.
I'm not sure what else we can do. We can?t duplicate the problem you are experiencing. I think you will have to keep trying different drivers.
If you send us your specification, we can try and duplicate your problem here. You can e-mail it to me and we can see if it is related to the specification file.
As a test, can you print from the sample data using a sample spec? Using the spec that's causing the problem?
