#39808 - 01/10/14 07:22 AM PO Filter request
Hi Softrak
A client wants to create a filter that shows all open PO's where the expected receipt date is in the past.
I couldn't figure out a way to do it without forcing them to edit the filter each time and change the target date. The closest I could come was to create a filter that showed PO's whose expected receipt dates were in the Last 30 Days.
Can you add "Today" as a field when building a filter and using the comparison option.
#39827 - 01/10/14 01:58 PM Re: PO Filter request [Re: Steve Schwartz]
Steve:
Today is available in PO as a Floating date range.
To get the results you want, and I would like to see as well, is something that will do Date < Today
#39836 - 01/10/14 04:54 PM Re: PO Filter request [Re: Douglas Dickie]
Hi Steve/Doug,
I can make a suggestion to include new Filter floating date ranges of 'Before today' and 'After today', to take care of both possible scenarios.
Steve: You are correct that the Last 30 Days floating range is the best you can do right now.
0 registered (), 91 Guests and 2 Spiders online.
14675 Topics
