I've tried that (and again just now), but it doesn't work. I can kinda see the screen flicker when I turn "Account Data" on/off, but it is nowhere to be seen :-(
What is the formula in cell F12? And do you have the Fiscal Period correct? If you use Departments, is the correct Department selected (or "Combined" instead of a single Department)?
Yes, Andrew ... I think Bruce is misunderstanding my issue. I've also had Andrew Peebles remote in to see what's up, but we cannot figure anything out regarding why the Account Data pane is not showing.
I bet it's showing up on a second monitor that is not connected. Reset your Windows screen properties to make sure that it knows you are only connected to a single monitor.
