#3906 - 03/16/04 07:30 PM Re: Stilla problem with Adagio Ledger 8 install
Phil M Offline
Adagio Fan
(142.179.55.201)
I have a client with the same problem. They are using Windows XP and W98 workstations running from a Linux server. Nothing has changed there since the original install (that I know of), but I am unable to install any upgrades or PTFs. I am able to manually create, modify, or delete files in all of the necessary directories, so I know that I have full rights.
I am also anxious to find the answer to this problem
-Phil
#3907 - 03/16/04 11:35 PM Re: Stilla problem with Adagio Ledger 8 install
Hello Phil M,
Installing a PTF "patches" an EXE to bring it up to the appropriate revision. This will fail if the EXE is marked "read only". Your post indicates a mix of workstations, but does not indicate where the install of the PTF fails. Can you install it from the XP workstation, or the Win 98 box?
1 registered (Softrak Support), 70 Guests and 0 Spiders online.
14567 Topics
