#38982 - 10/29/13 06:00 AM Double Sided Picing Slip
doug Offline
Doug Parrington
Loc: Winnipeg
I'm trying to create a 2 sided picking slip with different information on both sides. My problem is that I cannot get the detail lines to start over after the "end of page". I would like to get the detail lines on page one to also be on the flip side but with different information. Any suggestions would be appreciated.
Thank you
#38983 - 10/29/13 06:45 AM Re: Double Sided Picing Slip [Re: doug]
Hi Doug,
Why aren't you coming to the Boot Camp this afternoon? You could ask the assembled experts there for some insight.
#38986 - 10/29/13 10:17 AM Re: Double Sided Picing Slip [Re: Retired_Guy]
Doug:
It's not very clear what you are trying to accomplish. My guess is that you want to repeat the Picking Slip details on a different form (layout) to be printed on the back of the original Picking Slip.
This would only be possible using a tool called PrintBoss. Programming PrintBoss for this type of task would require significant expertise but I believe it could be done.
If you would be interested in engaging our services to deliver this solution please have your Adagio dealer contract me (204) 944-0302.
#38994 - 10/29/13 02:06 PM Re: Double Sided Picing Slip [Re: Douglas Dickie]
Hi Douglas (Dickie)
It's funny, I read Doug's posting and the first thing I thought of was PrintBoss. But I wanted to defer to you, and I'm happy you chimed in.
There's also the low tech approach of printing the invoices, then turning the paper upside down, feeding it back into the printer, and re-printing the invoices using a different invoice spec.
#38998 - 10/30/13 04:55 AM Re: Double Sided Picing Slip [Re: doug]
If your picking slip is ALWAYS a single page or less, then you can print a second copy on the alternate side. Otherwise you need PrintBoss.
#39082 - 11/06/13 09:15 AM Re: Double Sided Picing Slip [Re: Retired_Guy]
doug Offline
Doug Parrington
Loc: Winnipeg
Thanks everyone, the low tech approach is the right idea, except for the work involved. I will look into the PrintBoss tool.
Doug
