#37949 - 07/29/13 10:06 AM
PDF View Button Order Entry
Loc: Concord, On
After pressing the PDF view button on the Display History tab in Order Entry, the focus remains on the display history window. (Didn't think it worked at first until I noticed a second OE window on my task bar).
OrderEntry 8.1F (130708)
Edited by MikeS (07/29/13 10:21 AM)
Mike Smith Viktorian Sheet Metal Mfg Inc
#37950 - 07/29/13 11:05 AM
Re: PDF View Button Order Entry
[Re: MikeS]
That's how we want it to work. We don't want you to have to tab back to OE to look at another document.
#37974 - 07/31/13 03:47 AM
[Re: Retired_Guy]
Loc: Concord, On
Are you sure? I want to see an invoice so I highlight it in display history and then click the View PDF button. The pdf of the invoice opens but the focus immediately returns to the display history window. Then when I move off of the highlighted invoice, the focus returns to the PDF viewer (it's window now appears with the the previously highlighted invoice). If I'm in display history to see an invoice, I would like the viewer window to be the main focus after selecting the invoice and pressing view PDF.
In AR, under Vendors>Transactions, when I select an invoice and click the PDF viewer button, the focus remains on the PDF viewer window (the expected behaviour).
Why two different behaviours for what is essentially the same operation - viewing an invoice?
#37978 - 07/31/13 06:53 AM
[Re: MikeS]
Hi Mike,
You're right - the behaviour is different. It shouldn't be.
Thanks for pointing this out.
#37981 - 07/31/13 07:14 AM
[Re: Retired_Guy]
Loc: Concord, On
If you're going to be changing things, I vote for the AR behaviour.
#37983 - 07/31/13 07:58 AM
[Re: Softrak Support]
Loc: Concord, On
Good Afternoon,
That was pretty simple - worked like a charm.
Thank you
#38249 - 08/19/13 09:15 AM
[Re: MikeS]
Loc: Concord, On
I would like to make a suggestion that the Print button should be disabled when "Stay on top" is selected. I went to print an invoice I was viewing and the screen locked up. The print dialogue popped up but the Viewer retained the focus (I could only see the print dialogue by hovering over the task bar.) I had to close the dialogue window from the task bar and then select "Allow overlap" in the viewer. Everything was fine then.
Also with viewer, while I was trying to figure out what the problem was (I had forgotten that I had "Stay on top" on), I was playing around to get it to work. I selected an invoice in display history, and selected the viewer. After looking at the invoice, I minimized the viewer while the invoice was still loaded (my mistake), and selected 'Print' on the Display history tab. I then clicked on 'Print' which resulted in an access error (can't print to a document that's already open) and the screen freezing on Viewer (with no invoice now displayed). It required me going to the task bar and ending the task. Viewer also freezes if you select 'Preview' rather than 'Print' and then print the document from within preview.
0 registered (),
459
Guests and
Spiders online. |
14627 Topics
