#37747 - 07/09/13 12:52 PM Drill down pop-up menu
CHFManitoba Offline
Stranger
Loc: Winnipeg, MB, Canada
When trying to drill down to G/L details there is no option in the pop-up menu to select Details or Tx Details. I'm assuming we are an upgrade (or 2) behind but would like to confirm.
#37748 - 07/09/13 12:57 PM Re: Drill down pop-up menu [Re: CHFManitoba]
If it is a financial statement you are referring to, try double clicking on the amount.
#37749 - 07/09/13 01:23 PM Re: Drill down pop-up menu [Re: CHFManitoba]
You have to have selected a single cell that contains a number that can be "drilled into". Check your selection.
#37751 - 07/09/13 01:30 PM Re: Drill down pop-up menu [Re: Patricia B.]
CHFManitoba Offline
Stranger
I have tried that and it will just give a formula
Here is the formula in an example cell:
=-SUM(ADGET("gldata.BAL",$A10))
#37752 - 07/09/13 01:35 PM Re: Drill down pop-up menu [Re: Retired_Guy]
CHFManitoba Offline
Stranger
I've done that as well and I've also checked the Adagio Manual and the cell I have selected does contain a function listed in order to drill down.
Here is an example formula =-SUM(ADGET("gldata.BAL",$A10))
According to the Adagio manual Pag 3-93 If you have the function of ADGET you should be able to drill down.
Does it have something to do with the version of Adagio we have?
#37754 - 07/09/13 02:03 PM Re: Drill down pop-up menu [Re: CHFManitoba]
It's the SUM part that is preventing the drill-down.
You probably don't need SUM based on what the rest of the formula contents are, and may be able to use =-ADGET("gldata.BAL",$A10) to show the negative balance of the account(s) in cell A10 as of the selected fiscal period and year.
It may be desirable to see if your financial statements require 'cleaning up' to enable functionality such as this. For example, the ADGET formula has essentially been superseded by the GLAMT formula (though ADGET still works OK). If this is something worth pursuing, your Adagio consultant would be happy to assist you.
#37785 - 07/10/13 12:03 PM Re: Drill down pop-up menu [Re: Softrak Support]
CHFManitoba Offline
Stranger
That was the problem! Thank you! I've switched the formula from
=SUM(ADGET("gldata.B",$A8)) to =-ADGET("gldata.BAL",$A8) and the Drill down function is now working perfectly!
0 registered (), 125 Guests and 7 Spiders online.
14588 Topics
February
