#3739 - 12/15/03 06:25 PM Re: Manual check Batch
Please check the data integrity as this sounds like a corrupted batch file. If errors are found, exit the check, do a backup of the data, then re-run the check and the Rebuild function.
This may not be a fixable error and might require a repair.
#3741 - 12/16/03 12:14 PM Re: Manual check Batch
The data may be repairable by a Database Repair Technician.
However, before you consider a Database Repair, you may want to try restoring a backup.
If the error is in a small batch, you may also delete the batch and create a new one.
#3743 - 12/18/03 07:46 PM Re: Manual check Batch
Hello cgawryluik,
I'm sorry this hasn't been answered. Softrak can help you get your data repaired. Send an e-mail to carleeng@softrak.com to start the process. She'll provide all the details and steps necessary.
Thanks again
14630 Topics
