#3712 - 11/04/03 04:06 PM Re: A/R NOT BALANCING WITH G/L
Hello Oma Stewart,
What is the date on the deposits? (I assume you mean Pre-payments?).
#3716 - 11/04/03 08:12 PM Re: A/R NOT BALANCING WITH G/L
Hello Oma Stewart,
I would say that an integrity check should be done every day, and certainly before any backup is overwritten.
PS - I know you are probably used to entering all your information into the computer in all caps, but on a forum or in an email it is the equivalent of shouting. Were you really shouting?
#3718 - 11/05/03 11:04 AM Re: A/R NOT BALANCING WITH G/L
Hi Oma Stewart,
Just make a note that you should not be seeing an integrity problem more than once a year, even in a really high volume transaction site. If you are seeing integrity problems more frequently than that, then it is likely you have a hardware problem (usually network card related), unless you can create the integrity problem consistantly by performing the same sequence of steps. Use Adagio's File | Backup to make frequent backup's of your data - it only takes a few minutes, at most.
0 registered (), 125 Guests and 7 Spiders online.
14588 Topics
February
