#36922 - 05/15/13 06:35 AM
Re: OrderEntry 8.1E
[Re: Steve Schwartz]
It's possible that the anti-virus is checking the file when it's first opened. Also, the file is not very volatile, and so more and more of it will be cached in memory as inquiries are done. Also, it given the wide variation in the times, perhaps Windows is running out of memory and starts paging applications to disk. Look specifically for Outlook, and ask the order that the applications are loaded. Outlook grabs all the memory it can when it starts, there may be little left over for Adagio.
Perhaps it's time to purge some of that history?
#36925 - 05/15/13 09:06 AM
Re: OrderEntry 8.1E
Adagio
Loc: Vancouver, BC, Canada
Steve, The order of the fields you are selecting can be important. You should always have the smallest selection first. ie: If searching for a specific item then Item should be first. If searching for a customer over many items that should be first. The other thing to watch is if you are searching all dates or in a specific time period.
Can you tell us the ranges and order of the ranges that you have selected?
Chris McDonell Softrak Systems Inc.
#36931 - 05/15/13 10:52 AM
Re: OrderEntry 8.1E
[Re: Chris McDonell]
Hi Chris
I have done a lot of testing on this, and I think I nailed it.
When I pick a customer range BREE40 to BREE40, item range DABAR4620 to DABAR4620, for YTD, it takes about 1 minute to search and finds three matches, which is correct. It's the same no matter whether I make the item number or the customer first.
When I do nothing else but change the ending item number to DABAR4621 (there is no such number), it takes 5 seconds. Still finds the same three matches.
When I do nothing else but change the ending customer to BREE41 (there is no such customer), it still takes about 1 minute. Still finds the same three matches.
So there's something about picking a single item that slows the system down tremendously.
This is on my standalone Win7 PC.
If you would like the data (it's large), I'll upload it to you, let me know.
#36940 - 05/15/13 12:11 PM
Re: OrderEntry 8.1E
My quick test running OrderEntry 8.1E and the current service pack had the item history inquiry find transactions for a single specific item and customer (no ranges) in about a second, where the OEHLIN'R.dat data file was a shade under 500Mb and the programs and data are on a network drive (not local). The sort order for me was Item, Customer, Invoice date.
My ADS32.DLL is version 1.12.54.2989, which may be more current than what you have, but with current Adagio versions installed, the ADS is likely not too far behind.
I presume that your client's history is significantly larger than this, but I did not see any order of magnitude slowness when selecting a single item number for the inquiry on company data with a reasonable large history detail file.
As for your original question about 'what could have changed overnight', do they regularly do the single item/customer lookup? Just so the speed comparison is not based on the scenarios you found in your tests. Also, Miscrosoft released their round of Windows Updates yesterday, so it is entirely possible that one of these had an influence since this was a potential change yesterday. Anything else installed or changed at your client site yesterday, either Adagio related or not?
Regards, Softrak Tech Support
0 registered (),
160
Guests and
0
Spiders online. |
