#36455 - 04/09/13 11:09 AM Bank rec import of statement
Chris0111 Offline
Casual
Loc: Timmins, ON, Canada
Hello, I have accidently imported the statement to bank rec twice, can I not override the import so that there is only one to match? what do i do with the duplicates that are left? will they go away if npt matched?
#36457 - 04/09/13 11:58 AM Re: Bank rec import of statement [Re: Chris0111]
Assuming that you have not deleted the file downloaded from the bank...
Mark all the Bank statement entries as "Deleted" (click on the first, shift-click on the last and press the Delete key) and reset all the pending statuses on the Adagio side. Exit the reconciliation function and start again.
#36459 - 04/09/13 12:15 PM Re: Bank rec import of statement [Re: Retired_Guy]
Chris0111 Offline
Casual
Thank You.
#36470 - 04/09/13 05:21 PM Re: Bank rec import of statement [Re: Chris0111]
The strategy I use is to make a backup of the BankRec data prior to importing. Then if there is a problem I restore from the backup.
#36496 - 04/10/13 02:16 PM Re: Bank rec import of statement [Re: Steve Schwartz]
Another tip is to edit the grid on the left-hand side of the reconciliation screen (the imported records) and add the 'Import Sequence' column. This value increments for every import with a unique number.
This way you could differentiate between the first and second import, multi-select the entire second (erroneous) import and press the Delete key to delete them all. This is similar to Andrew's suggestion.
0 registered (), 115 Guests and 2 Spiders online.
14659 Topics
