#3625 - 09/18/03 10:01 AM Softine's Item Number Change
I was using Item Number Change with IC. I used it to change and combine sku codes. Also for old codes not in use, I thought if I created a junk code and combine all old codes into it, This would be better than deleting (as in the past deleting codes has caused data intregity errors)
Is the Softline progam compatible with our adagio IC. Also I'd like to get the Vendor Number change, as many of our A/P have changed names.
Plse advise if I can do this.
Thanks Elvira
#3626 - 09/18/03 10:05 AM Re: Softine's Item Number Change
Hi Elvira,
Yes and no (mostly yes). If you have not created any Notes for your inventory items, then Softline's product should be OK (although I'd always recommend doing everything on a copy of a data and running extensive integrity checks before doing anythin to your live set). Oh yes, it also won't update Adagio OrderEntry's historical Invoice archive.
Ditto for Vendor # change (without the OE comment ).
#3627 - 09/18/03 01:47 PM Re: Softine's Item Number Change
4 minutes to answer my question. That's some service!!!!!! Thanks Andrew
Elvira
