#36117 - 03/15/13 07:28 AM Un-Build..Un-Assemble
Polygons Offline
Stranger
Loc: Hamilton Ontario
Within Assemblies, does the "unbuild" function require the BOM add-on module? I do have "Allow negative Inventory" enabled. After entering "-1" for quantity I see the "Build" button switch to "Unbuild" yet I am notified that the integer must be positive.
Thank you.
#36121 - 03/15/13 08:40 AM Re: Un-Build..Un-Assemble [Re: Polygons]
Unbuild requires the BOM add-on.
Not sure why you are getting this error. What versions of OE, IC, & BOM are you using? Is BOM licensed or has it expired?
#36122 - 03/15/13 10:26 AM Re: Un-Build..Un-Assemble [Re: Douglas Dickie]
Polygons Offline
Stranger
Thank you. I was starting to suspect that was the case.
#36124 - 03/15/13 11:03 AM Re: Un-Build..Un-Assemble [Re: Polygons]
MikeS Offline
Loc: Concord, On
I had the same error and then found out I required the BOM add-on. For the hundred and fifty or so unbuilds/builds I do a year, the add-on wasn't worth the cost.
