Hi James,
When you get the message 'Not all data is related' in Quik Reports DOS, invariably this means that the defined links are not set correctly.
The first thing I would suggest is to reinstall the TBR program through the System Manager. If you ever had to reinstall Quik Reports for any reason, this will throw off the link tables for all 3rd party products and require reinstallation to set that back up.
After this, try again. If you continue to get errors, then go to the Edit menu and choose Links. You may have to choose a new link field in case the default field chosen was not correct.
