#35607 - 02/18/13 11:17 AM
GridView can do this, but how?
A client wants 10 salespeople to be able to view one-day-old receivables information, each salesperson looking at their specific customers only. The report could be a PDF or an Excel spreadsheet. They have created a folder for each salesperson on their server, and that's were they would like each report sent.
They want the reports updated "automatically" every evening. They are comfortable using Task Scheduler.
I know I can use GridView to generate the report, and build 10 filters, one for each salesperson. But how can I have it "automatically" create 10 Excel spreadsheets, each in a different folder depending on the filter.
I might add that it takes a few minutes to recalculate the GridView, so the fewer recalcs needed, the better.
Not as critical, but they have two sister companies, with shared salespeople. It would be ideal if each salesperson's report contained two customer lists - one for each company. In Excel this would mean two separate sheets. If this is not feasible, they are OK with getting two separate reports.
Thanks for any suggestions you might have, especially if they involve GridView functions I am not familiar with.
#35618 - 02/18/13 12:53 PM
Re: GridView can do this, but how?
[Re: Steve Schwartz]
Who said anything about logging in 10 times?
This is going to run overnight as a scheduled task. The batch file will contain 10 separate invocations of GridView.EXE with different filters specified on each invocation. The resulting spreadsheet will be placed in a known Folder. The next line in the batch file copies the workbook to its final resting place for the salespeople. Then the workbook is deleted and the next GridView.EXE with a /XDW parameter is invoked.
#35619 - 02/18/13 12:54 PM
Think about creating a multi line "batch file" with all the correct /XD parameters on the individual lines and then scheduling the running of that file.
G:\Softrak\GGVWin\GVWin.exe /.......... G:\Softrak\GGVWin\GVWin.exe /.......... .... .... G:\Softrak\GGVWin\GVWin.exe /..........
It will be able to get you exactly what you want.
#35624 - 02/18/13 02:08 PM
[Re: Retired_Guy]
D:\RD\Softrak\GVWin\GVWin.exe /c /usys /psys /d:D:\RD\Softrak\APWIN\SAMDATA /e:SAM /xdw:"D:\RD\Softrak\APWIN\SAMDATA\Views\VendorBalances.gvs" /XDF:"GVVendorBalance:NotZero" /F:"D:\RD\Softrak\APWIN\SAMDATA\Views\User"
The above will automatically load the WorkSpace D:\RD\Softrak\APWIN\SAMDATA\Views\VendorBalances.gvs
Apply the filter "NotZero" to the View "GVVendorBalance"
Send the result to Excel
Save the XLS(X) in
D:\RD\Softrak\APWIN\SAMDATA\Views\User\XDViews
Create a log file called GVLog.log
Time to start experimenting....
#35633 - 02/18/13 07:23 PM
Workspace with a single view may not apply the filter, the work around is to Add a 2nd View to the Workspace and and set the recalc Order..
File | Set Workspace Recalc Order
Any View you want to go out to Excel must have Allow Export
If you don't want the 2nd View to be exported untick Allow Export
If you must send your work use
File | Gather files for support
and zip collection and upload to data repair attention Michael
1 registered (Salman),
222
Guests and
2
Spiders online. |
1874 Members
14561 Topics
