#34811 - 01/09/13 06:30 AM Gridview Filters
Are Gridview Filters limited to 50 lines?
#34812 - 01/09/13 07:10 AM Re: Gridview Filters [Re: SusanTennier]
I think the limit is related more to the maximum number of nested IF() clauses or characters, not lines.
When Filters get this complex, it's often well worth while to look for alternative ways to select the records you want to consider.
What is the Filter trying to accomplish?
#34831 - 01/09/13 11:06 AM Re: Gridview Filters [Re: Retired_Guy]
We thought the same after exceeding the limit so we've reverted to an alternative.
The issue now is that we added a new item today and it won't show up on Gridview. We're using "I/C Item Locations Master". The item is active at one location. What are we doing wrong?
The only filter we have on this is: {UPC} = "ABC"
Edited by SusanTennier (01/09/13 11:09 AM)
Edit Reason: last sentence added
#34834 - 01/09/13 11:16 AM Re: Gridview Filters [Re: SusanTennier]
I suppose I have corrupt data since it's telling me that I can't make it inactive because there are quantities on hand when there isn't.
#34839 - 01/09/13 12:10 PM Re: Gridview Filters [Re: SusanTennier]
This would have happened in the last 8 hours?
#34841 - 01/09/13 12:11 PM Re: Gridview Filters [Re: Retired_Guy]
Yes. DataCare will likely rebuild it tonight. I'm hoping we can get through the rest of the day.
#34844 - 01/09/13 12:16 PM Re: Gridview Filters [Re: SusanTennier]
Can you send me the View?
#34846 - 01/09/13 12:44 PM Re: Gridview Filters [Re: Retired_Guy]
I added another item and it's in the view. There's a problem only with one item added today, but other items added today are okay.
#34848 - 01/09/13 12:48 PM Re: Gridview Filters [Re: SusanTennier]
Does the item appear in the GridView view with the filter disabled? Just so we know whether to focus on the data or the GV filter.
#34849 - 01/09/13 12:53 PM Re: Gridview Filters [Re: Softrak Support]
No. It won't appear with or without filter.
#34850 - 01/09/13 12:55 PM Re: Gridview Filters [Re: SusanTennier]
OK. So the likely culprits are an integrity issue or the item was not saved in that company data being looked at by GV.
#34853 - 01/09/13 02:12 PM Re: Gridview Filters [Re: Softrak Support]
The field {UPC} does not exist in the Item Location file.
#34854 - 01/09/13 02:29 PM Re: Gridview Filters [Re: Retired_Guy]
I inserted related column and hid it. GETEXTERNALDATA("@N81CICM", "UPC", "ICITEM", {Item #})
Adagio Inventory: File Integrity
Item Locations ... 2 error(s) found ............................................ FAILED
File Integrity ... 2 error(s) found ............................................ FAILED
Rebuilt
Made the item active.
Problem solved.
#34855 - 01/09/13 02:29 PM Re: Gridview Filters [Re: SusanTennier]
OK. Just checking.
