#33815 - 11/09/12 06:48 AM Optional Text Combo Type
MikeS Offline
Loc: Concord, On
I found the optional text fields in the I/C Item (3) Extension table but where is the data stored if I'm using it as a combo box?
Thank you
Mike
PS Is there a limit to the number of items that can be stored?
Edited by MikeS (11/09/12 06:49 AM)
#33821 - 11/09/12 08:33 AM Re: Optional Text Combo Type [Re: MikeS]
Hi Mike,
The elements are stored in the same file, regardless if you choose to select them in a Combo box or Finder field. I don't believe there is any practical limit.
#33822 - 11/09/12 08:39 AM Re: Optional Text Combo Type [Re: MikeS]
BAMPH Offline
Paradise is perspective
Loc: Christ Church, BARBADOS
Hi Mike,
I'm not sure if I'm understanding your question but...
When doing item maintenance, the data that you select from the "combo box" is stored in the item record in that table you mentioned above. So if you were doing a GridView that included the optional fields from that table, you should see the data that was chosen from the combo box when the item was created / edited being displayed in your view.
If you are asking where the combo box list of items are actually defined... Inventory Module | File (Menu) | Optional fields ...
I'll leave the limit question to Softrak but are you asking about the limit on the number of items that can be listed as choices for the Combo Box or the limit of Inventory items/products ?
Regards, Pete
Edited by BAMPH (11/09/12 08:41 AM)
Edit Reason: Typo fix
Peter Banfield
BAMPH Consulting Services
Barbados
#33823 - 11/09/12 08:56 AM Re: Optional Text Combo Type [Re: BAMPH]
Michael Mulrooney Offline
The actual values are stored in a file called SDOPFV'D in the data folder
#33826 - 11/09/12 10:44 AM Re: Optional Text Combo Type [Re: Michael Mulrooney]
For GridView:
Module: "Adagio Common Files"
Table: "Optional Field Values"
0 registered (), 444 Guests and 0 Spiders online.
14621 Topics
