Hello Printer,
To print reports, Adagio needs to know the location of the \QRASP directory. This is set during installation as the Report tables drive. This path is stored in the Windows Registry.
If the path is pointing to a drive that does not contain the QRASP folder, then the error is generated. A similar error will be generated if the drive indicated in the path actually does have a QRASP folder, but does not contain the proper tables for the Adagio module you are trying to print the report from.
I suggest that you reinstall Time&Billing. Do a Custom Install and pay special attention to the drive that is set as the Report tables drive.
