#33357 - 09/24/12 11:38 AM Statement group - 1 stmt printing cons. not dept
MER Offline
Loc: Ontario
When I print my Monthly F-S, which I have set up as a Statement Group in Financial Reporter, one of the balance sheets prints out for all departments even though I have it set up to be for just 1 department not consolidated. Any ideas on how I can get this statement within the statement group to print correctly?
#33359 - 09/24/12 01:05 PM Re: Statement group - 1 stmt printing cons. not dept [Re: MER]
Hi EMB,
Which version of Adagio Ledger or FX are you using?
If you have created a Statement Group and added a financial statement to print for a specific department (and not for the consolidated setting), this should replicate the display if you open that particular financial statement and select the department from the toolbar. If you open the balance sheet statement and select that department, do you see the same unexpected results regarding 'consolidated', or does it appear as you expected? What about for a different department - expected or 'consolidated' results?
If the display is also incorrect outside of the statement group, then the problem has to do with how your financial statement is defined. Do your balance sheet accounts use departments - if not then only those accounts that have departments will have amounts selected (and accounts with no departments will print with zero). Perhaps the formulas are not set up to read the department from the toolbar - ensure that column B (or wherever the account numbers are set) use the -` as the department selector. If just account numbers with the dash and the ` character, it's possible that only consolidated values will print because you have not defined departments to be part of the statement.
If the display is correct when loaded manually, and the problem only occurs when using the statement group, then the statement group settings are not set up correctly. Edit the statement group and ensure that the options are set as you expected them to be.
#33362 - 09/24/12 01:21 PM Re: Statement group - 1 stmt printing cons. not dept [Re: Softrak Support]
MER Offline
Loc: Ontario
Thank you. I'm actually at the Adagio training in Thunder Bay, and I just got Andrew to fix it for me. The problem was that I had the dept assigned to all the balance sheet accounts, but not to the summary revenue and expenses.
Thanks again.
1 registered (1 invisible), 221 Guests and 1 Spider online.
14672 Topics
